20 Most Recent
Lowrance iWAY 250C GPS Receiver Questions & Answers
Lowrance 250c map update
http://www.lei-extras.com/store/search.asp?SearchType=Unit&Unit=iWAY+250C
You need to buy the Navteq map update, but you can call them and send in your memory card they will update it for a reduced cost, since 75 plus 12 shipping is too much just for maps, you can buy a whole new one.
I lost the charger I replaced it with other one
Having the same plugin doesn't guarantee that it is the correct polarity (if dc) nor the correct voltage, nor that it is AC when you require DC etc. If you put the wrong adapter on and you are not very electrically inclined... you can blow the power circuit inside the unit.
Lowrance iway 250c wont charge?
The rechargeable battery is more than likely the problem and will need replaced, or the charging circuits are not functioning, "less likely"
The maps on my i way 250c are out of date - how do
you may update them by accessing the factory website for your device
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Need a fully working Lowrance 250C GPS Sd card
I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
Charging post
Hello
A quick question. Have you tried to look up a place to fix it the advertisment area of this site???
there are some good techs and then the prices are more competitive?? Let me know and I will find a few places in your area.
Also,how far would you travel(in miles) from where you live?
Cant get the usb cable or port to recognize the gps
This is the info from the Lowrance website
Begin with the iWAY 250C turned off, not just on stand-by. Stand-by is the default setting for the unit when powering down. Change the settings in the interface menu to power off instead of defaulting to stand-by when the power button is pressed. Connect the iWAY 250C to an available PC port. With the PC turned on and operating, turn the iWAY 250C on. The PC should make a sound recognizing a USB connection. If there is no audible sound, try another USB port on your PC. If there is a tone of recognition and the iWAY 250C is not displayed as a separate drive in My Computer, there may be a drive conflict. Change the drive letter of the iWAY 250C. Click here if you have a drive conflict with Windows 95, 98, or ME.
Touch screen failure
Sometimes it pays to procrastinate. My 250c gps was left in a drawer for a year and a half as I hesitated to pitch it. I turned it on recently and everything works good as new. The battery was still fully charged! It must have dried out over time.
No longer receives GPS signal
Does this unit have an input for an external antenna? If you get/borrow another antenna you could see if it starts working. That might isolate the problem to the antenna.
I would like to reset to factory settings
Hi.
Only soft reset is available.
This will reset all settings to factory, but will not erase personal data.
To do soft reset boot up holding the MAP/MUSIC button and the power button at the same time. Leave buttons only when you see that the scroll bar at the bottom has finished. The iWAY will reset to default settings.
Just bought at auction. No manuel.
My apologies. I see now that you have an iWay 250C. Here is the manual as found on the Lowrance website.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iWAY250c-manual_0160-201_080706.pdf
THE PROBLEM IS AFTER BEING
when it happens just restart or reset the gps or gps lock from settings.
if you can't find gps reset from the menu, then look for a reset button on the device, should work normally again.
