The spark electrode on our AEG Electrolux gas cooker hob will not stop even after the gas is ignited.
Gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Gud day,the main problem of ur cooktop is the micro swicth inside the unit,difficult to repair it if u are no have idea how to repair,this micros swicth is color blue or red connecting to main power & igniter transformer,u can see the mico swicth if u remove the knob,but if u want to clean the micro swicth first unplug the unit then remove all the screw at the top of unit to remove the stainless cover then u see the all the parts,if u see the micro swith remove it carefully,remember b4 u remove if remember the place & possition for returning purpose only,to clean the micro swicth u see if the parts have a clip lock to see inside the switch,always the problem of the switch is grounding (common problem) clean using the brush or check it if have grounding the contact.sory for not perpect enhlish.tnx gerbee
I removed the control knob and found it perfectly clean. I also removed the hob cover disc to expose the elecrode, but found this clean also. Have purchased a hand held ignitor to use for the time being. The hob and oven have only been installed a few months but we did not fill in the guarentee.
could you tell me the location of the battery for the ignition on gas hob electrolux please
Fix
can i have the wiring diagram to the proline cooker hob
