20 Most Recent Smeg 23 in. SE64 Gas Cooktop Questions & Answers
Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
8/22/2017 6:32:28 PM • Smeg 23 in. SE64... • Answered on Aug 22, 2017
Flame leaking under lower ring. Common?
no it is a problem with the hob consider this as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
9/23/2015 9:51:15 AM • Smeg 23 in. SE64... • Answered on Sep 23, 2015
0answers
New cooktop ! long flame yellow tips black
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
12/25/2013 2:53:53 PM • Smeg 23 in. SE64... • Answered on Dec 25, 2013
2answers
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
8/2/2013 12:27:21 PM • Smeg 23 in. SE64... • Answered on Aug 02, 2013
Smeg gas cooktop is continually clicking.....going mad,,,,,
Ist unplug the unit. What you have is the stovetops valve switch defective. Sometimes this will happen after a boil over. The switches get wet and temparaly short. When they dry out it should work properly.http://www.on-timeappliance.com/ovenrepair.html
3/27/2012 1:16:12 PM • Smeg 23 in. SE64... • Answered on Mar 27, 2012
Hi my ignation is not
Hi,That is not that hard to fix and you can easily buy the parts yourselfonline...Here is a tip that will help you with the online buying...How to Buy Appliance Parts OnlineHere is one site that I recommendhttp://ping.fm/zJDAMheatman101
9/22/2011 12:39:28 AM • Smeg 23 in. SE64... • Answered on Sep 22, 2011
One of my igniter in
Hi,Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..Cooktop Range Stove spark ignition does not workheatman101
9/22/2011 12:39:02 AM • Smeg 23 in. SE64... • Answered on Sep 22, 2011
Hi may ingnation
Hi,Here is a tip that will help you to get better results from your question onFixya.How to ask a question on FixYaheatman101
9/22/2011 12:36:56 AM • Smeg 23 in. SE64... • Answered on Sep 22, 2011
When I turn and press/hold knob, the burner
... and that is exactly how it is suppose to work ...
8/19/2011 2:46:14 AM • Smeg 23 in. SE64... • Answered on Aug 19, 2011
Are all the plates supposed
Yes, that is a safety feature and your cooktop is working properly.
5/6/2011 12:11:35 PM • Smeg 23 in. SE64... • Answered on May 06, 2011
Automatic igniters run continuously.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/19/2010 12:14:33 AM • Smeg 23 in. SE64... • Answered on Aug 19, 2010
The ceramic self igniter wont stop sparking help
Here is a tip that I wrote that will help you with that...
heatman101
7/25/2010 3:24:55 AM • Smeg 23 in. SE64... • Answered on Jul 25, 2010
My smeg cooker is brand new! after cleaning it -
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
5/5/2010 3:34:59 PM • Smeg 23 in. SE64... • Answered on May 05, 2010
All 4 of the hobs started sparking/ clicking after
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
2/26/2010 4:09:12 PM • Smeg 23 in. SE64... • Answered on Feb 26, 2010
2answers
Auto ignition won't stop
If you accidently got the igniter switches wet, this will happen. If you lose a good ground on he unit this will also happen. Check both of these to see if that helps.
5/2/2009 4:37:26 PM • Smeg 23 in. SE64... • Answered on May 02, 2009
Smeg 23 in. SE64 Gas Cooktop Logo
35 questions posted
Top Smeg Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Smeg Cooktops
  • Smeg Cooktops
Most Popular Question
flame leaking under lower ring common
  • Cooktops
