20 Most Recent Smeg 20 in. SRV532X Gas Cooktop Questions & Answers
The gas keeps cutting out of my SRV532X. Fuel is
You probably have a bad gas regulator. Have a service repair technician replace it. Good luck!
11/7/2009 12:24:56 PM • Smeg 20 in.... • Answered on Nov 07, 2009
Smeg induction cooktop flashing E A?
Hi Ross, The error code E A on your Smeg induction cooktop indicates a communication error between the electronics of the cooktop and the specific burner. This could be caused by a fault in the electronics of the burner, a wiring issue, or a problem with the main control board of the cooktop. You can try to reset the cooktop by turning off the power supply to it and then turning it back on after a few minutes. If the error code persists, it is recommended to contact Smeg customer service or a certified technician for assistance in diagnosing and repairing the issue.
4/23/2023 7:24:01 AM • Smeg Cooktops • Answered on Apr 23, 2023
Model SE395ETB. Just installed. Why doesn't it work?
if we could only test it but alas we can not
10/24/2021 5:53:32 PM • Smeg Cooktops • Answered on Oct 24, 2021
New smeg gas stove top and one of the cooktops does not click or ignite. How can I fix it?
Take the burner off and boil it in a pan of boiling water and soap. Leave to cool, rinse and dry. That should fix it. grease is insulating the grounding for the spark. I have come across it many times. Having said that, how new? Still under warranty? Call them out!
9/13/2021 2:55:03 AM • Smeg Cooktops • Answered on Sep 13, 2021
2answers
SH OR 5H error code on my smeg induction and no heat
It's the showroom mode. Try the following workaround to deactivate it.https://smeg-service.co.uk/support/video/22/deactivating-showroom-mode-on-smeg-hobs
11/19/2020 11:45:57 AM • Smeg Cooktops • Answered on Nov 19, 2020
I have a smeg sai63 induction cooktop and we cant turn on any elements, there is power what could be the problem?
THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter.( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advicebcuzGod is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges,the oven temperature sensor is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- element burner testing range element-short.2-undefined-undefined-0_2.gif element test bake broil with meter-undefined-undefined-2.jpg fuse location oven fuse_ranger_17-undefined-undefined-5_1.jpg
3/17/2020 6:46:30 AM • Smeg Cooktops • Answered on Mar 17, 2020
2answers
Why won't the interior light on my Smeg SUK92MFX5 oven turn off.
These smeg ovens have a door switch (switch is on panel just behind top of door ) of may have moved or door has not been put on properly
8/30/2019 7:11:53 AM • Smeg Cooktops • Answered on Aug 30, 2019
3answers
SMEG induction cooktop SA610SS not turning on
8/30/2019 6:45:06 AM • Smeg Cooktops • Answered on Aug 30, 2019
How to fix igniter switch of smeg gas cooktop
Take a brass wire rush and ru bing alcohol and gently clean the wig iter tip maki g sure to remove as much burnt material as possible
2/17/2019 6:58:43 AM • Smeg Cooktops • Answered on Feb 17, 2019
2answers
Smeg cooktop how to unlock child lock ?
Read in user manual, or check manufacture web site
10/2/2017 1:19:08 PM • Smeg Cooktops • Answered on Oct 02, 2017
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail call smeg and see if there is a replacement one available there may be after market units from your local gas shop
1/1/2017 2:22:38 AM • Smeg Cooktops • Answered on Jan 01, 2017
How do I unblock gas jets took top off
Use a small piece of stiff wire and gently clean out the orafice. Or soak in oven cleaner.
7/4/2016 3:06:12 AM • Smeg Cooktops • Answered on Jul 04, 2016
0answers
A smeg hob
Be the first to answer 6/3/2016 12:00:25 PM • Smeg Cooktops • Posted on Jun 03, 2016Be the first to answer
Why is the ignition not firing on my smeg gas cooker
It may be dirty. Try cleaning it and let it dry.
8/30/2014 2:33:45 PM • Smeg Cooktops • Answered on Aug 30, 2014
Oven drawer stuck
It's stuck on the runner,only way is to use a wood pry tool to force it open
8/18/2014 10:14:22 AM • Smeg Cooktops • Answered on Aug 18, 2014
Smeg 20 in. SRV532X Gas Cooktop Logo
Popular Tags
2 questions posted
Top Smeg Cooktops Experts
ADMIN Andrew
ADMIN Andrew
Marty Warge
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Smeg Cooktops
  • Smeg Cooktops
Most Popular Question
gas keeps cutting out srv532x fuel
  • Cooktops
