You need a new screen!!! www.computereworld.com I can fix this for $170 total, that is a new screen and the labor. submit a request on my site, or call me 662-549-2362
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL] Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
my screen is all black with white lines
