I pulled cover and examend for broken parts or springs. Everything appeared OK. I run just water, no clothing thru cycle. It did not jump as bad, but still seemed excessive from what I recall.
SOURCE: excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
SOURCE: the spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
SOURCE: The Washer did not spin
Hi, A couple of possibilities. Do you know if the washer actually agitates during the wash cycle? If the coupler is bad, the washer runs but doesn't agitate or spin.
The other option is the spin basket drive assembly. If you was to put something into the lid switch actuator and start the spin cycle while the washer in empty, try and turn the tub with your hand and see if it spins. If it does spin, the basket drive is week and will need changed.
Please let me know if this helps or if I can assist you further.
Vic
