Transcend StoreJet 320 GB USB 20 Hard Drive Logo
Leon Posted on Nov 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Transcend 320gb is being detectedon devices and Printers but not visible on My Computer
Brian Sullivan
Level 3:
  • Transcend Master 27,725 Answers
  • Posted on Nov 12, 2012
Brian Sullivan
Transcend Master
Level 3:
Answers
27725
Questions
Helped
5670261
Points
79191
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
I am using Transcend 320GB USB hard disk. Contents of few folders are accessible and some are not. when i try to open the folder whose contents are not visible, a message pops up saying that disk is not...
Did you try running software from windows to try repairing it? disc scan etc, There is plenty of help on your computer or on the net to repair lost or corrupt files and most of it is free, Treat it like it is the internal hdd on your own computer but tell your computer to scan that disk instead of its own internal hdd, it does work as i use this method myself, Go to start-my computer-you should see your external hdd there, Right click and go down to properties, Click on that and go to tools, Use tools from the drop down menu and try repair it from there, There will be one called check now and tick both boxes, Hope this helps,
My transcend 320gb external hdd sometime disconnected automaticall. At present i can not even view my valuable data. If the folder inside the hdd are not show by my computer, how can i recovered my data...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
I have got transcend storejet 25M 320Gb external hard disk.....when i started using it i transferred some data from my PC to the hard disk and the transfer speed which it was showing was 1.2mbps which is...
You connected it to a "USB 1.1" socket in your computer, which is only 1/40 of the speed of a "USB 2.0" socket (if your computer has any such USB sockets). If you don't have any USB 2.0 ports, buy a PCI add-in card to add some ports to your computer.
3helpful
My 320GB WD Hardrive keeps blinking. It is connected via usb 2.0 into my laptop (windows7). Computer Management says it's working properly and it displays all the folders but when I want to open the...
It seems that your Harddrive has problems with internal Micro USB connector. WD, Transcend and Seagate brands are having such kind of problems.
Try to adjust the micro usb cable in such a way that your data transfer or ongoing activity will not hamper. Else to have perfect solution on your problem, backup complete data from the HDD and hand-over the HDD to the nearest WD technical department.
They may diagnose the issue and if not resolvable, will handover new WD Harddrive.
Thanks,
Amar
My transcend 500GB external hard disc suddenly not visible on my computer, though its detected.
well first you check your hard disk by inserting in other computer and if it works then the problem is in your computer. so check for the driver in device manager and also problem consist then you can solve this problem by repairing your operating system.
I m using transcend 640GB.when i connect it to system explorer is not notifying the device.but it is visible in device and printer section of device manager
Probably a drive letter conflict
go to disk management, right click on the trancend drive and change drive letter, choose a letter further down , maybe T for trancend
Transcend 320GB is recongized as "unformatted"
Here is an article with some ideas on how to solve issues with an external hard disk.
If it does not work, one last option is to take the hard disk out of the case and connect it directly to the SATA or IDE interface in your computer.
1helpful
2answers
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
6helpful
3answers
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
