Transcend 160Gb StoreJet 25 Unveils... • Uploaded on Sep 30, 2013
first thing is to try to find and fix the computer crashing problemtest all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even the electical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
make sure the CPU has a secure dust free seating with thermal paste
make sure your ram modules are securely seated with no dust in the sockets also the Cmos battery has charge with no dust in the socket
on some motherboards cmos batteries are soldered in
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
24 questions posted
187 Questions
94 Questions
5 Questions
