We have the GE front load washer wbvh5300k2ww and the rubber seal inside the door on the tub that catches things has a rip in it and drains water. Our clothes are still clean but it is leaking EVERYWHERE what is that rubber thing called?
SOURCE: Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
SOURCE: Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
SOURCE: front loading washer leaks
The rubber seal (or bellow) wears with age and will eventually deteriorate over time. Excessive use of detergent, and/or use of the wrong detergent (detergent that is not HE) can contribute to rubber breakdown too. Regular detergent is formulated for washers that use a wash tub with a capacity of 35 gallons. HE detergent is formulated for High Efficiency washers that only use 5 to 7 gallons of water. So, if you place regular detergent in an HE washer, you are (in affect) putting a higher concentration of soap in your washer. This higher concentration of soap can act as a corrosive to rubber and become permeated in your clothing as it does not rinse completely. This can lead to skin irritations as well. It is important that if you are not using HE detergent that you do so in the future to prevent premature breakdown of the rubber seals of the washer and pump. This will also void most manufacturer warranties if it determined you are using improper detergent. Now...I'm not trying to accuse you of abusing your appliance and not trying to lecture you. I'm merely putting this information out, because some people simply do not know. Overloading the washer is another contributor to excessive wear on the bellow as well as not keeping the bellow cleaned properly. Mold and mildew can contribute to the break down of rubber. The following link can give some advice on proper care of the door bellow:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
Since your bellow is already leaking, it must be replaced. Replacements can be ordered on line at either searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these websites offer competitive pricing, so you can shop for the best deals. Just type in your COMPLETE model number to begin your search. The Sears website offers helpful exploded view diagrams to assist in part identification and location. NOTE: You may consider ordering the front and rear bellow clamps if yours are damaged. Refer to the Sears website for pictorial view.
If you need assistance in replacing the bellow, the following link will give you the steps necessary to complete this repair on your own:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
