Turned lights off the other day and the front and rear park lights stayed on, can only turn off by removing fuse - relay that switches when switch turned on appears to work OK - removing relay lights stay on Have disconnected looms to rear of vehicle turns off rear lamps, have removed fuse holder and checked behind for shorts - Ok
SOURCE: passenger side front and rear parking lights staying on
Return the direction indicator stalk to the central rest position to cancel the parking lights.
SOURCE: blower motor does not work
I had the same problem, replace, replace, replace. Check, check and recheck. What I found was the blower motor resistor, located in the blower squirrel cage area, two prongs and a curly wire, was bad. Took the new one back, (it ohmed out okay, continuity ok, all ok!) replaced it with another, and Bingo, problem solved. Frustrating to say the least. After two relays and a blower switch, and test, test and retest. It was a faulty resistor. Made in Mexico. And no guarentee, even though new, it works. Trial and error. Even the dealer parts are Honcho en Mexico. Thanks NAFTA. You gonna make us all welfare babies.
Found problem - fixed
Hi Kevin - I have the same issue, what was the problem/fix?
