Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Posted on Mar 24, 2017
My Sharing tabs Are Missing on my windows vista laptop
I'm trying to connect my xbox 360 up to my laptop so i have the use of xbox live.
But i'm missing both sharing tabs in my local area connection and my wireless connection.
Cause i've gone to propeties on both of them and it's prompted me to continue. So i do but no sharing tabs at all.
So i can't connect my xbox up.
Can someone please tell me how to get that tab up and showing so i can click on it.
This is what it says atm.
THE SHARING TAB WILL NOT BE AVAILABLE IF YOU HAVE ONLY ONE NETWORK CONNECTION.
So if that means that i need to add another network connection. Can you please tell me how in detail.
Thanx
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Sep 20, 2008
SOURCE: can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Anonymous
  • 213 Answers
  • Posted on Oct 14, 2008
SOURCE: Cannot find server or DNS Error
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Internet Explorer
No matter what I do I keep getting this message when I try to use NEW VERSION IE.
Anobik Som
  • 136 Answers
  • Posted on Nov 27, 2008
SOURCE: Error 734: PPP Link control protocol was terminated
I think you are trying to connect with Bluetooth...
try with Data Cable please.
Anonymous
  • 43 Answers
  • Posted on Jan 06, 2009
SOURCE: xbox 360 live using internet through my laptop
Normally you would connect your xbox directly to the router. Is there a reason you are trying to connect to your laptop instead? (distance, etc.)
If that is what you truly want to do then first thing make sure you are using a CROSSOVER cable to connect your laptop and xbox together. standard network cables only apply to connecting to routers, switches, and other network controlers. If you are connecting two devices directly you must use this type cable. It is ussally red.
The share tab is only for sharing dialup connections to LAN connections. You are sharinbg two LAN connections so all you need to do is bridge them and make sure there are in the same IP group. Check the status of your wireless card to see what address the router is assigning to it. Then assign the IP to the wired adapter with a differnt higher number.. Example: If your wireless card is 192.168.1.100 then make your wired adapter 192.168.1.151 This should make it work.
Again, it would be much easier to connect your XBOX to the router like it was intended ;)
Anonymous
  • 63 Answers
  • Posted on May 30, 2009
SOURCE: Windows Vista Home Premium can not find xbox 360 as an extender
Use ORB. Google it and you'll never look back! Have fun!
Trying to get Xbox live connected...
Follow these steps if you are trying to use a laptop :
1.
Make sure that your XBOX 360 is fully functional and your laptop is connected to the internet by means of a wireless card.
2.
Locate the Ethernet cord and connect it to both the computer and XBOX 360. Don't turn on the XBOX 360 yet.
3.
On your Vista, click "Start" then "Network". After select the tab "Network and Sharing Center." On the left tab, click on "Manage network connections." You will see a Local Area Connection and a Wireless Internet Connection.
4.
Use your mouse to select both icons and right click. Click on Bridge Connections. Turn on your XBOX 360, Sign In, and you will find yourself connected to XBOX LIVE.
5.
Once you are done, and you need to use your computer for other uses. Simply right click on the Bridge Connection and select disable.
For more information on how to connect and use xbox go to the link below you will find all the details :
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
3helpful
3answers
I do not know how to connect xbox 360 to my vista laptop. i plugged in the Ethernet cable to both the laptop and xbox but it doesn't show the xbox 360 on the network connection after i've clicked ''manage...
Remember to thumbs up this solution if it helps, if not comment for further assistance.
Plug your xbox into the laptop with an ethernet cable
Turn on your xbox
On your laptop press start, click on network
In the blue bar across the top click network and sharing center
click on manage network connections
right click on local area connection
click properties
click sharing tab
untick top box.
Go on your my xbox page, scroll over to the right to the system settings page, network settings,test connection.
This works for me.
Cannot connect xbox live
please follow the instructions below to solve your problem
How to setup yourpc/laptop to allow you to connect to xbox live
go to my computer right click on the hard drive then select properties then click on the sharing tab and click on advanced sharing, then click on share this folder then, ok, apply, ok, then click start at the bottom left of the screen, control panel, network and internet, network and sharing center,
then change the following settings.
network discovery= on
file sharing=on
public folder sharing=on (password required)
password protected sharing=on
media sharing=on
then right click on the internet connection icon at the bottom right of your screen
then do the following click on connect to network select your dongle right click and go to properties go to the sharing tab click on the allow box at the top of the sharing tab then apply your settings if done successfully then it will say you have to disconnect and reconnect your internet for your changes to take affect do this and your set-up and ready to go.
hope this helps you
1helpful
How do i get xbox 360 live on my windows vista laptop with a vodafone usb 3g dongal thingy? plzzzz help if u can
Plug your xbox 360 into your laptop with an ethernet cable, turn xbox on, press start, click on network, in the blue tab across the top click on network and sharing centre, on the left hand side click on manage network connections, right click local area connection, click on properties, click on sharing tab, un tick the top box, go to your xbox go on my xbox,go over to your system page and test the connection, this worked first time for me,but I did have issues trying to connect my laptop to the internet when I had done, to resolve this I went onto the network connections page, right click on wireless network, click on diagnose, then reset network adapter this sorted it out.
Hope this helps.
How to connect my xbox to xboxlive in nigeria
if you have a usb modem and a laptop it is real easy. I hav been playing xboxlive in nigeria since i move here, but it is not as much fun. your ping or latency is goin to be really high because of the facts that there is no xboxlive in nigeria and nigerian internet aint that good. you will hav to join British or American xboxlive. its sumtimes fustratating. ill give the steps in any case
1) connect xbox 360 to laptop with ethernet cable
2) change ur ip of xbox to 192.168.0.2, and ur pc ip to 192.168.0.1
3) do not do anything to DNS
4) Go to network and sharing center >> manage network connections >> right click on dail up icon >> properties >> click on sharing tabs, and check all blocks. click apply ok and what not
5) try to connect to xbox live, it wont work right away, so try and try
6) if u hav any problems, search it on google
NOTE: Thins is for Windows Vista and Windows 7
I have tried to connect to xbox live
you need to make sure you have enabled ICS, Internet Connection Sharing. To do so, you go in to the internet settings (found in the network sharing centre)choose your net connection, click 'view status' and then click properties (the first of three buttons at the bottom, properties, disable and diagnose) then once the window pops up, there is a sharing tab, check the box that states 'allow other users to connect to this computers internet connection' after that simply dis connect and re connect and the new settings will be able to be used once you do a xbox live network test. Good Luck.
1helpful
Xbox 360 live using internet through my laptop
3answers
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in 192.168.1.2
9.Subnet mask
10. type in 255.0.0.0
11.default gateway
12.Type in 192.168.1.1
On your computer
(vista)
1.start
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
10. 192.168.1.1
11. subnet
12. 255.0.0.0
13. default gateway
14. 192.168.1.2
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Maxicube.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
