Battery Is Fine Tested With Battery And Without Took Out Battery Power Cable Held Power Button For 30 Seconds To Reset No Luck Powers Up For About 20 Seconds Fans Come On And With Only One Light Flashing A Lock Symbol With A Nine In It Any Help much Appreciated.
SOURCE: Dell E1505 not turning On
That's a good posibility. Here's a link for Dell diagnostic codes and the manual for your machine.
http://pompone.cs.ucsb.edu/admin/530_Workstation/2codes.htm#1170334
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=e1505+diagnostic+light+codes&cat=sup
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
SOURCE: Inspiron 1501 won't turn on
do you have the dell diagnostic CD??
if you have it may help you to figure what is wrong??
here is th link to the troubleshooting steps.
http://support.dell.com/support/edocs/systems/ins1501/en/om_en/html/trouble.htm#wp1062918
I suspect the hard drive may be on its way out. unfortunately you can't see the screen.
SOURCE: Dell Inspiron 6400 won't power up...
Most probably the seating of the processor on the motherboard is not proper
check this site and mount the processor properly
http://support.dell.com/support/edocs/systems/ins6400/en/sm/cpu.htm#wp1084976
SOURCE: red light flashing on far right symbol/battery or charger going ?
this happiness when you've used the laptop off power for some time. it indicts your battery levels. when the battery level is low to a certain %ge then it warns you before its totally empty. always power up your laptop whenever it lights or save your work in order not to lose unsaved data.
SOURCE: Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Please dont forget to vote this answer was helpful
Many thanks
