Fuel lines dissolved need diagram to route them to carb and primer bulb
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
SOURCE: replaced new gas line, new primer bulb, new
Line from tank with the filter on it is the supply line and goes to the
carb inlet fitting. This is typically on the "bottom" of the carb (with
the tank being up) and will usually have a fitting with barbs or a
bulge on it to ensure a tight fit. The other fitting on the carb is the
return line and is usually a straight tube fitting with no barbs. That
line goes the suction side of the primer bulb. The third line goes from
the outlet of the primer bulb to the return barb fitting in the bottom
of the tank. Fittings have to be removed from tank to properly install
the new hoses on them. Remove retainer ring on outide of tank and push
fittings into tank, then shake out of the fill opening. More details on
replacing hoses are listed in another post about Repairing Ryobi
trimmer.
Have you checked the spark plug?
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
