Says power saving mode when turned on,how do i get it to turn on properly
Throw it!!!!
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
SOURCE: My monitor will not stay on. Gateway FPD 1530 15 in.
The Inverter Board needs to be replaced. (Easy to repair)
SOURCE: Won't come out of power saving mode
chek the connection cable between the CU and the Monitor and the power supply cable of the montor or give another outlet
SOURCE: Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
SOURCE: cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
SOURCE: When I turn on my Gateway FPD1530 Monitor, it
Replace one or two 1000uf electrolytic capacitors in the power supply.
Monitor Mike
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
