The transmission is not changing gear automatically as it normally would
It can be the issue with Transmission or problem with gear shift assembly.The system has to be inspected and tested.---------- http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html ------------- Car is stuck in park and the shift will not move? http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html ----------- http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html ---------- http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html ------------- http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html ---------- http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html ------- http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html --------- http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html ---------- http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html -------- http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html ---------- http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html --------- http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html -------- http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html ---------- http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html ----------
For complete step by step troubleshooting,click the solved help links with complete solution for such various solutions.
Click the link below:----
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will Not
shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
SOURCE: 2005 Toyota Corolla with 36,000 miles Transmission now "jumps" into gears
hi,
when the check engine light comes on, your car goes into a mode where instead of everything being normal, things are forced, to try and compensate for something else being wrong. It most likely does need a new timing belt, and a complete tuneup INCLUDING plugs and wires. we have a 1984 toyota corolla and it purrs like ground rice, I suggest the tuneup to continue proper rice production.
J
SOURCE: 1996 Corolla Auto Transmission problem
Hi. 2005 Corolla CE. It's normal. They tend to do this when upshifting form 1st to 2nd gear. No timing chain readjustment needed.
96 Corolla. Overdrive not working properly, if not engaging after 45mph constantly. If driving on the city, is normal, but not after 45mph, when the car is trying to engage overdrive in order to save gas and preserve the trans gears. If not able to get help at the dealership, find another one and explain them the situation.
SOURCE: 1994 toyota paseo: overdrive problem
does it loose heat when you set still? is it full of coolent? whats the climent like were you at? is trans. low on fluid?when was the last time trans. was serviced? i know on most cars and trucks low fluid or old fluid can cause it to do what your saying, and also cold weather. some cars have a temp.sensor that won't let it shift into overdrive until car gets to a certain temp. with your temp. guage fluctuating the two could be related. has your service engine light ever come on and then went out, when it did this? if it ever has, have it scaned and see what codes show up. it might be that temp sensor i talked about. well thats the best i can do for you RON hope it helps or at least point you in the right direction to cure your problem. OLD SCHOOL.
SOURCE: toyota surf automatic it wont change gear ?
I assume you are saying it is late to shift. There is what is called a Throttle Valve ( TV) cable that goes from the engine to the transmission. If this cable is out of adjustment, or too tight, it will cause this problem. While you are at it check for vaccuum leaks on the hose from the engine to the tranmission. A problem here will cause a harsh shift, but necessarryly late shift
Good Luck
SOURCE: 1996 Toyota Camry is slow to change gears when accelerating
Automatic Transmission: Is your speedodometer working fine? Not jumping around one irratically? My inlaws Ford Taurus would act like that, but when their problems were present their speedo wasn't functioning. I changed out their speeo sensor and the problem was solved. I'm not saying that's your problem, but if your computer is relying on your speed sensor to tell it when to shift and the sensor is not working it the computer will go into a safe mode and not allow the transmission to shift (automatic transmission) out of 2nd gear. Otherwise I would lean toward transmission troubles. Could be as simple as changing your transmission fluid and filter. If the filter has never been changed with those kind of miles its long long overdue. All you do is jack up and support the front of your vehicle on jack stands remembering to block the rear wheel with a 2x4 or something large that the vehicle can't roll over and then place a drain pan under the transmission oil pan. If it has a drain plug then simly remove it and drain the transmission fluid into the drain pan. When done draining, replace the plug. If it doesn't have a plug then you will have to loosen all of the bolts holding the Transmission oilpan just a little bit and then work on loosening the bolts to the rear of the oil pan so that it drains from the rear of the pan allowing you to more accurately determine where the fluid is going to come out at. You may have to lightly pry the pan loose from the transmission if it doesn't start to drain once the rear bolts are loosened. You want to only loosen the front bolts about 2 full turns and then gradually as you work your way back loosening them just a little bit more the closer you get back to the rear of the transmision oilpan. The front of the vehicle is already up in the air so the oil should run to the back of transmission oil pan. Finish draining it and then remove all of the bolts and remove the oil pan from the transmission. Look at the new filter so you know what it looks like when you look for the old one to remove. Look to see how it is fastened up into place and remove the bolts / screws holding it in place and then remove the filter and put the new one on. You may have the design where it's held on by pressing it on with your hand because it has a rubber seal attached to the filter. After the filter is in place you need to use a clean rag and clean and dry the mating surface on the transmission where the oil pan touches. If there is a gasket there then you will have to remove and replace it with one from the Filter Kit. This should be done anytime you remove the pan. If it is a rubber style gasket then you will not need any RTV sealant. If it is a paper or cork gasket then you need to purchase a sqeeze tube of RTV sealant. Pay attention to the package details of the RTV because not all are for transmission fluids. If you need to use the sealant then read the directions carefully and then re-install the new seal. Put the Trans Oilpan back into place and if you are using RTV then make sure that when you are tightening down the bolts that hold the pan to the transmission that you do not over tighten. You don't want to sqeeze all of the sealant out from between the mating surfaces. Remove your jackstands and unchalk your rear wheel, then lower your vehicle back down. Under the hood you will need to find where the dipstick is and with a funel, refill the transmission with the recommended transmission fluids that is right for your make and model vehicle. If you are not sure then ask your local parts store.
Manual (Stick Shift) transmission: you may have a bad clutch or worn out throw-out bearing. If you let out on the clutch and the vehicle feels like the clutch is still partially engaged and it takes a lot more gas to get to speed, then it sounds like you've smoked your clutch due to either normal ware and tare or operater driving habbits. I would look into replacing the clutch. Inspect the flywheel for discoloration like bluing or yellowish colored metal that idicates that it has gotten HOT. You'll have to drop your transmission out and then you will need to remove the clutch and fly wheel. Inspect the flywheel for cracks. If you see hairline cracks around the bolt holes or anywher else on the surface then you'll have to replace it. If you do not see any cracks then take it to shop or parts store that have the capabilities and can look it over to make sure it didn't get to hot (to hot means the temper in the metal has been taken out. Temper is the hardness of the metal, so if the temper has been lost, then the flywheel could be brittle and dangerous if re-used. You may be in luck and the flywheel didn't get to hot therefore allowing you to be able to keep it and just have them turn a new surface on it with their lathe. Just like when you have your brake rotors and brake drums turned. Replace the throw-out bearing, pilot bearing, clutch and presure plate. Re-assemble. You should buy one of those cheap (i.e. cost not quality) clutch alignment tools for re-aligning the clutch to make your job much easier.
If you are not comfortable with working on your own vehicle or don't have the tools then take it to someone who can. Recommend taking it to the professionals. These suggestions may or may not fit your specific problem(s), but without knowing more information these are merely suggestions.
