Washing machine starting to beep half way through the cycle flashing on end also leaves water in the drum so not draining or spinning on end of cycle will i have to bite the bullet and buy new or can we fix it.....filter cleaned out,outlet pipe clear
Not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
please i am a bit thick computers=very good
washing machines=not very good
impellor.... plus where is the pump located shall i take the back off it and have a poke around lol.....
I checked the filter and it is clean. I put water from the drain pipe and compressed air and the drain pipe is clean and open.
