I LOST MY MANUAL AND CAN'T REMEMBER HOW TO LOG ON TO MY PHONE TO HEAR MY MESSAGES WHEN I'M NOT HOME.
This instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Answering Machine On
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
SOURCE: how do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
