You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
If Sony Remote RM-YD035 does not change channels or turn off TV the buttons got dirty coz those are your most used buttons. You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result! To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing. Clean both parts thoroughly. And then genlty put them back together and push tuwords each other. The parts will snap closing. You are done. Mine is now working perfectly
I'm not sure why people are still commenting on this. My answer solved it. -- It's done.
your answer was completely uneducated and has nothing to do with the problem
SOURCE: need code for my for my sanyo tv using sony universal rm-vl600
http://esupport.sony.com/perl/model-remote.pl?mdl=RMVL600
SOURCE: sony remote RM-V202A
Follow these steps to program the remote control.code for NEC:(003, 012)
SOURCE: Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
SOURCE: Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
