Star Manufacturing Star TSP700 Receipt Thermal Printer Logo
shihwei hwang Posted on Oct 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
I have the legacy port convert to USB port. What port should I select when installing manually. I've tried LPT or COM1 and USB but none of them seem to work with the driver and the problem persist. Any other suggestion?
Anonymous
Level 3:
Genius:
  • Master 1,447 Answers
  • Posted on Oct 05, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1447
Questions
Helped
468102
Points
4051
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another computer
What you are experiencing and have attempted is a bit ambiguous. Is the printer repeatedly printing the same document or is it just kicking out blank pages after printing the document? Did you retrieve a second printer of the same model and print successfully with it or did both fail? Did you try the "bad" printer on the 2nd computer which you got the 2nd printer from? The answers to all of these are relevant. A document may be repeatedly printed if "stuck" in the printer queque. Blank sheets may be perpetually ejected if the nozzels are clogged. Driver installation may not have been successful if instructions about unplugging the USB cable were not followed. For that matter, did the driver match the OS and come from the manufacturer? There are a lot of factors to sort through here. Hopefully, this gives you some ideas. Whether Star Micronics offers support for a printer of this vintage is anyone's guess. I just see a Model II of this model when I begin looking into the printer. You might want to repost, clarifying what the problem is and what you have tried. Sorry.
I need drivers for my lexmark z640 printer on windows 7 64 bit
Copy and paste link need for driver required!
Windows 7 64-Bit
http://support.lexmark.com:80/lexmark/index?page=content&locale=EN&docLocale=en_US&segType=
driverSegmentMICROSOFT&userlocale=EN_US&id=DR16280
Windows 7 32-Bit
driverSegmentMICROSOFT&userlocale=EN_US&id=DR16272
Hope this helps; if so please let FixYa know.
Tom Miller, Eng
1helpful
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
1helpful
My machine is not printing,even though it said 100% normal
Hello:
Check to be sure the drivers you installed (I'm assuming you installed the drivers) are for the operating system you have on your computer. If it's Windows Vista or Windows 7 be sure you checked to see if your version of Windows is either 32 bit or 64 bit.
The best thing to do is uninstall the printer and reinstall it again this time making sure you have checked all the Windows info correctly. You can do this by clicking on the start button then find the "computer" or "my computer" then right click on it and select "properties" on the bottom of the list. All your computer info will be displayed for you to determine which Windows operating system you are running including if it's 32 bit or 64 bit.
After you've reinstalled the printer and the correct drivers and it's still not working you may have to have it checked out. The printer spooling service may not be running on the computer or your printer may be damaged.
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
2helpful
2answers
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Printer say's "please load paper in auto
This could be a printer driver problem. Try to uninstall your existing Lexmark X4270 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark 4200 Series > Tools > Uninstall. After the process, reboot pc when prompted.
Check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to re-install the printer driver on your computer: - Lexmark X4270 Driver for Microsoft Windows 7 for 32-bit - Lexmark X4270 Driver for Microsoft Windows 7 x64-bit
1helpful
It seems that the driver to print did not install. i can fax, copy and scan but not print. message - no compattable printer installed. i did download it from the web aswell. im having an hp620 notebook...
It could be a printer driver issue. Try to uninstall your existing Lexmark S405 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark > S400 Series > Uninstall. After the uninstall process, reboot pc when prompted.
When your pc turns on, go to Start menu > right-click on Computer > Properties. Take note of the System Type (32-bit or 64-bit).
Use the links below to reinstall the printer driver: - Lexmark S405 Driver for Windows 7 (32-bit) - Lexmark S405 Driver for Windows 7 (64-bit)
Cannot print to lexmark x7550 printer. it seems that printer is able to scan but not able to print. already installed the software, but when connecting the printer to the computer with windows 7, it...
Try to use the Windows 7 driver from the Lexmark website. Uninstall the existing driver from your computer first. How to Uninstall Lexmark Printers. Reboot pc when prompted. Then, check if your Windows 7 is running on 32-bit or 64-bit system type by going to the Start menu > right-click on Computer > Properties. Take note of the System Type.
To reinstall the driver, use the following links below: - Lexmark X7550 Driver for Windows 7 32-bit - Lexmark X7550 Driver for Windows 7 64-bit
3helpful
3answers
Black lines on scans and prints HP 2727nf
File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Top Star Manufacturing Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Star Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
