It run few minute and cut off on my mercedes benz e420
SOURCE: My 1995 Mercedes Benz E420 has lost power gradually
Have you check the transmission fluid level? It sounds like it is low. You might not have a dipstick in that unit. I'd add at least 2 quarts and test drive it.
SOURCE: benz e420 multiple cyl missfire
also check and see if the updated Mass Air Flow sensor has been installed, these go bad all the time causing all kinds of weird misfires and other problems.
SOURCE: 1995 mercedes benz e420 turn
check fuses then relays if those are fine most likely the switch has gone bad but i am pretty sure fuse
SOURCE: whee is engine computer ecm locate on benz 1995 e420
RUN THE scanner and computer do not waste the time and your money. The EMC OR BCM is faulty or speed sensor faulty with the scanner determine which is faulty.
God bless you
