@ larry
You can get the Restriction code or Unlock code for Nokia 2730 Classic (2730 C1) at Onnlinegsmunlock.com/nokia-2730-classic/rs7wp9/
and unlock it from network lock easily.
If your BlackBerry stays powered off with a black or white screen,
follow the instructions below. The only indication of life might be the
blinking red LED light in the top corner. Nothing seems to wake it up
and Desktop Manager doesn't recognize any device is connected.
1) Make sure you have Blackberry Desktop Manager installed.
http://na.blackberry.com/eng/services/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5)
You should then see a list of applications ready to be installed for
your Blackberry. Hit Next and Finish and you are well on your way to
getting your Blackberry back to life. Congrats! Just don't disconnect
anything and let the lengthy process finish completely.
NOTE: If
you do not see a list of applications mentioned in step 5 and instead
see the message "The Blackberry Desktop Software does not have
Blackberry Device Software for the device that you have connected to the
computer. Contact your wireless service provider or system
administrator," then you must download Blackberry's Operating System for
your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just
select the appropriate carrier and network type, select your Blackberry
model from the list and download the latest version. Install this
download and follow the above steps again and you should be on the right
path.
Source: http://supportforums.blackberry.com/t5/BlackBerry-Curve/Curve-8520-stuck-on-a-quot-white-screen-of-death-quot/td-p/490308
What is your problem in your blackberry...The video is not clear...You can pleasse specify it correctly or you can go to nearest blackberry service care to fix it...
