20 Most Recent
RIM BlackBerry 8700 Questions & Answers
How to unlock a cell phone
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from
Blackberry server which wont void your warranty, & generate code
based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work
with single network, you can use your in any part of world with any
network
including your browser & MMS picture messaging to work, yes with
just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com/
How do I lock my keypad
hi,
The simplest way to lock keypad in most of the blackberries is, to hit "alt+enter".
(or)
you can press "k" quickly to lock the keypad. But you should disable the option of "Dial from Home screen" for this.
thanks, have a nice day.
How do i set up text on blackberry 8700
For you to set up text on your blackberry, go to the message icon and okay it.Once on the message icon you can click on the home button and a menu appears, scroll to compose SMS. You are then taken to the sms page where you can now enter the cell no. in the TO: field and the text space lays under it where you can type in your text message.
Hope this helped.
Regards
I lost my address book icon on my blackberry 8700
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
There is an hourglass on the screen and the phone
Remove the back cover and remove and reseat the battery. Allow a few minutes for it to boot back to your main screen.
Then, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Blackberry problems
Try to charge it with another adapter
if it will not help probably your batery is dead
