Sony Ericsson XPERIA X2 Smartphone Logo
Venita Henkel Posted on Oct 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone on slide lock & touch-screen inoperable
Touch Screen frozen with slide lock on
Anonymous
Level 3:
  • Master 580 Answers
  • Posted on Oct 05, 2012
Anonymous
Master
Level 3:
Answers
580
Questions
0
Helped
127604
Points
1888
Ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
5 Related Answers
Anonymous
  • Posted on Jan 23, 2008
SOURCE: touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jun 09, 2008
SOURCE: SonyEricson P900- Touch screen is not working AT ALL ! !
Try a master reset on the phone. If this doesn't help then the hardware has malfuntioned and the phone will need to be serviced.
Anonymous
  • 24 Answers
  • Posted on Dec 21, 2008
SOURCE: m600i touch screen
Past experience shows you will not satisfactorily resolve this problem until the LCD panel is replaced. Spares are reasonable easy to source, e.g. (ebay.com, item number 280296211660).
Anonymous
  • Posted on Mar 11, 2009
SOURCE: w960i sonny ericsson frozen touch screen
jackiehutchi wrote:
"take out the sim card and underneath is a tiny black switch (lump of black plastic the size of a pin head) this was sticking out and not flush to the rim so I pushed this in."
Take a toothpick and carefully push that black plastic untill it kinda "locks"
Source
Anonymous
  • Posted on Jul 21, 2009
SOURCE: W950i TOUCH SCREEN NON-FUNCTIONAL
Screen display on my Sony Ericsson W950i is not working.
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Samsung soul touch screen frozen
I think the touch screen of your phone is faulty, may be you have to change it for it to work again.
Take care
2helpful
2answers
Screen frozen and slid bar is locked
Hold the lock and home button until the apple sign shows up then start over.Your welcomed
My touch screen is frozen, side buttons & call buttons work but the touch screen just does'nt work.
it shows the sensor on touch is not ineractive with the pen, may be you should unscrew the phone to see if flex is damaged and replace it with another one.
8helpful
2answers
LG ENV TOUCH IS FROZEN. WON'T POWER DOWN, TRIED
You should try taking out the battery for at least ten minutes then putting it back in.
Jun 27, 2009 • Cell Phones
Frozen touch screen
try a hard reset then try again *2767*3855#
2answers
Touch screen issues
i recomend either a flip cover(if available) or a thick screen protector that lowers sensitivity.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
