20 Most Recent
Sony Ericsson XPERIA X2 Smartphone Questions & Answers
Phone on slide lock & touch-screen inoperable
ur defalt phones codes is 12345 or 00000 u can use itType *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
I have the problem for boot my cellphone.
HiTry resetting it.But note that this will delete your personal data,downloads and third party applications on the phone restoring to its factory settings.Start >Settings >System >Clear phone memoryFollow the instructions.
The screen went blank after it dropped
Hello,there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phonesGood luck.
Imma getting so fed up with xperia x2's
Just make sure that you are killing the apps that are still running in the background, goto settings , task manager and then end all there to close all applications in memory, the open apps in the memory would be eating at your battery..
