MANUAL FOR MODEL VN 600PC
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
SOURCE: vn-4100pc no guide
Go to www.olympusamerica.com click the link for product support and then go to the Digital Recorder section and click on the link for the VN-4100PC and then click the link for Instruction Manuals. There you will be able to download a PDF copy of the instruction manual.
SOURCE: Need instruction manual for OLYMPUS digital voice
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1388
Here is the link to the Olympus website where you can download a copy of the user manual.
SOURCE: How can I optain a manual to operate the Olympus VN-4100PC voice recorder?
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1291
Here is the link to the Olympus websote where you can download a copy of the user manual
SOURCE: Failure to install Olympus VN 600PC
Yes, you need a vista compatible Digital Wave Player software version, file eng_2000_xp.zip
available here:
http://www.olympus.co.uk/consumer/2590_software.cfm?category=8&productgroup=347&product=420&os=10&result=
Install the DWP software first, then plug the recorder in and install drivers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Olympus-VN-6000-Voice-recorders-manual/id/23662ag824/t/2/
