Non idrive
I had a small nail in the near new tyre that BMW service said needs replacing. I took it to my local tyre guy and he fixed it although he said he shouldn't. Happy days!
For X1 you need to turn engine on and use the scroller on the indicator stalk to get the reset indicator, then hold the BC button on the end of the stalk for 5 secs. I had to do it twice but prob solved.
Believe it or not, it's in the owners' manual...
SOURCE: BMW 320D,2006- run flat tyre warning light is on. How do I reset?
Using the indicator stalk, navigate to the tyre pressure reset option, press the reset button twice in short succession but hold it in the second time until a tick appears on the display
SOURCE: I've had 4 new tyres fitted to my 2006 BMW 320d and
Insert key press start button,push scrool on top of indicator stalk,untill you see tyre warning. Then press end of stalk to reset
Testimonial: "perfect. I've tried resolve myself for the past week and took a couple of seconds with the information provided. Many thanks"
SOURCE: Tyre pressure loss warning indication how do i
Insert key don,t touch brake/clutch pedals
Press start button
Use scroller on top of indicator stalk,push up/down utill you find reset
When you find it press and hold button on end of stalk
You will see reset
This is for 3 series without sat nav,if you have nav re post as it is a different reset
SOURCE: run flat tyre warning light is on i have checked tyre pressure
This will only come on when a tyre has dropped in pressure (not spare). It work on the principle that a tyre with less air has a smaller rolling circumference and therefore a different wheel speed. This is then monitored against other signals from other wheels and determined that a loss in pressure has occured.
If all tyre pressures seem ok, there could be a chance of a small unoticeable leak and would require a bath test. This is when the tyre is dipped in water and bubbles would appear where the puncture is.
Ultimately the system may just need to be reset, or has incorrectly been reset from a tyre change. For this you just press and hold the TPC button (located on the centre console above the gearstick - looks like a flat tyre with an exclamation) turn on the ignition to position 2 and the light will come on re then yellow,go out, come back on yellow. When it comes back on yellow it re-initializing the system. You can let go of the button and after 20 odd seconds the light will go out for the final time, completing the reset.
If the light continues to come on after the reset then you definitely have a puncture somewhere!
Hope this helps!
SOURCE: need to reset to run flat tyre warning light on
i have a bmw , 1 series, i have just put air in my tyres and there is now a warning light on the dashboard, have i over inflated my tyres?
