This can also mean that the operating system can not find the boot partition.
first check if in BIOS the right disk is the boot disk. You will have to push Del or F12 or other during startup. Check boot order. Choose your first harddisk to boot from and click F10 to save and exit.
If that is right and you tries all harddisks and still not booting, try to start up from a rescue disk or the original operating install disk.
for Windows:
given options: install on disk, tthen if already installed Windows found, choose repair. Choose repair startup.
First download and install daemon lite tool in your pc : second right click as shown in picture on game image file and bring cursor on open with and select daemon lite tool now come on desktop start the game through the shortcut on desktop the best way for playing game which ask for cd rom
Games and programs cannot be copied from one computer to another, because there are various files are installed (system) in different locations and may include some registry entries. Most games need to be installed onto the computer and you need the games installation disk.
Download deamon tools lite. http://www.daemon-tools.cc/ENG/downloads That will allow you to make virtual drives. Put the files you downloaded into that drive. The game will see it as a disk in a cd drive and your should be able to install as normal.
dont know what crack is? : 1. insert disk.. 2. open my computer and find the drive where the disk is inserted, 3. right click on the selected drive and in it find the folder crack. 4. copy the image of the game inside the crack.. 5. and paste it to the original folder in your computer..
It is because vista is the worst windows i have ever seen in my life. there are many{not many lots of} games which do not work not even install on vista. There is no way through you can install games {sorry} pls rate me thankyou
Run the Setup.exe file in compatability mode (right-click the setup.exe icon and select properties, then select compatability and choose a 32 bit version of XP). The game was not tested on 64-bit Vista and isn't likely to work outside of 32 bit compatability mode.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Your going to take your disk (if muiltiple disks, then take the first disk or any disk that says something like "install" on it or something) and simply insert it into your CD-ROM drive. A screen is going to pop up. It should be a GTA San Andreas screen. There should be a button that says "install". Click that and simply go through the process. If there is any option, once you press the "install" button, to do a default or standard install or a custom install, just choose default or standard. The game should start to install. If there are multiple disks then in the middle of the install its going to ask for the other disk(s). What you do is when the window pops up asking for another disk, just eject the disk that is already in your computer and insert the other one. Once the other disk is in, close the CD-ROM drive and it should continue the install.
