20 Most Recent
Macplay Baldur's Gate II: Shadows Of Amn for Mac Questions & Answers
"Please Insert Disk 2"
try cracking it..
dont know what crack is? :
1. insert disk..
2. open my computer and find the drive where the disk is inserted,
3. right click on the selected drive and in it find the folder crack.
4. copy the image of the game inside the crack..
5. and paste it to the original folder in your computer..
hope this will help you
My game won't save help!!!!
Spotlight interferes with the way the program saves. Open spotlight preferences and click on the privacy tab. Tell spotlight not to search your save games folder. then it should work fine.
Shadows of Amn crashes randomly when I try to
This happened to me, also. I don't remember which forum it was, but I found a solution. The problem is Spotlight. You need to prevent it from "looking" at the files in the game, as it causes crashes. The path is: System Preferences (under the 'Apple' in the upper left of the screen --> Spotlight (sub-heading of 'Personal') --> in that window, you can toggle between "Search Results/Privacy". Go to "Privacy" and drag the entire BG II folder into the window. This will prevent the crashes upon saving.
Umar Hills wont load.
I have the same issue, the game asks for disc 3. It can read the disc i used it to start up the game it has nothing to do with the switching discs. I had the BG folder open with the game on small screen. I went to other areas, i use the ToB disc and in the BG folder when i went to other areas, it reads the folder i.e. disc 2. and i didn't have to change discs. but it didn't read the folder disc 3 when i went to umar hills WTF. I reloaded the game too but still fails.
After I installed Baldur's Gate II on my MacBook,
I love that game dude, but it's old and sadly depending on the OS you have, it doesn't run. You're probably using Mac OS X, or even Mac OS X Snow Leopard and BG2SoA doesn't run on Mac unless you have bootcamp.
I've started a multiplayer game and assigned all
the problem is that the game doesnt know who to assign the moves or charachter settings to try with one extra character and the n up more and see where the errors start you dont say how much memory you have as the more characters the more memory you need to run multiple threads..Good Luck A
Macplay baldurs gate 2 disk ejects before loading
I manage to start the game on Mac OS X Leopard. I have burn the CDs (CD 2 - 3 - 4, because you need them to play) and than, to solve the problem of "ejects of the disk" I have also mounted the image dmg. Then to start the game I insert the CD 2 for example, then I mount the disk image dmg (the same that I have burn on the CD) e then I open a file .bif in the folder CD2/Data/
The computer open this file and start the game!
Gimmy
Installation problem
hi
it is coz of old drivers or ur system does not meet the requirments of the game
Can't start multiplay
Just do a multiplayer game with 1 person assigned to you. If that works, keep going up in 1s. It might just be that the amount of people you are trying to use is just too big for the computer to handle. Keep going up in 1s until it no longer works.
Error 89
Error 89 is probably something wrong with it actually loading the new map. Theres probably a script error with the transition 'compasses'. I suggest cleaning the disk as well as possible (if you havent already tried), and, if that doesnt work, i think its a good idea to get a new disk.
How to be a good Battlemage
Obviously there is no battlemage class. What you do is start off as a warrior class, but change the attributes. then level up 2 times as a mage, and then 1 level of warrior. You cant wear the armour, but you can use the weapons!
Hope you enjoy it!!!
Baldur's Gate II Keeps crashing!
uninstall anything you dont need is a good start. If, when you have done this, it persists, then reinstall the game. If it still does it, check if all the system requirements match to the RECOMMENDED, NOT MINIMUM. Some games wont actually work on minimum. Plus, some games dont work on some operating systems.
Please rate me.
