Angelia:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
SOURCE: I have a whirlpool Quiet Partner I. HELP Drain light flashing
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
SOURCE: Quiet Partner II Whirlpool Dishwasher 2 years old,
Unusual LED or Display Readouts Open ID diodes and/or LED circuit(s) in keypad, or open circuits on the control that drive
See "Checking Keypad Operation."
Press the following in sequence...Then try touch pad......
HEATED DRY ? NORMAL ? HEATED DRY ? NORMAL ? HEATED DRY ? ORMAL
here is the deal...if the touch pad is unresponsive after entering the above in sequence then you will need to change out the touch pad.
here is the link to your model....part number 1 on the drawing...there are three different ones....the difference is the color.Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPBA/1198/0130000/W0702219/00002?blt=06&prst=&shdMod=
Here is a link that will show you the three differnet colors...I would order from these guys....1 year warranty on parts no questions asked
click on the link http://www.repairclinic.com/Touchpad-Parts?s=t-DU1100XTP-%3d%3dc63
SOURCE: My Whirlpool Quiet Partner II
have you tried powering it down,shutting off power to the unit for 15 minutes,sometimes the electronics will glitch as a computer does,if this is to no avail,then try removing all connections from the interface(control panel) to the main control panel and clean each cable and re-plug in,then see if this solves your problem,otherwise it may be time to replace either the interface or main control board
