Hardly no color adjustment. red and tint wont adjust not good picture. everything just red and green background. hardly any blue just red and green. cant converge blue wont work looks green.
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
tks its very helpful. how do you get high voltage block up?
My Samsung 54 inch rear projection has the same problem. It was moved to the basement when the Plasma arrived. It worked fine before the move but now when the Perfect Focus is selected using the remote it cycles through aligning Red and Green but fails to do anything with Blue. The pictures Tint isn't good.
i have sme problem with coolbreeze1.like to know how fixperfect focus. thanks
just red and green color on rear projection tv
