WOULD THE HOMELITE CHAIN SAW BE TWO STROKE MIXTURE PETROL AND TWOSTROKE OIL 100 ML PER 5 LTRS
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
SOURCE: Need fuel/oil mixture ratio for a poulan 3400
Hi, fuel/oil mixture is 40:1 for Poulan. Hope this helps.
SOURCE: My Husqvarna 455 saw is only using about a 10th ot
the saw should use tank of oil to a tank or fuel.if not you will wear out chains and bars very quickly.there should be an adjustment but see as you are under warranty go back and dont take NO fof an answer
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
