20 Most Recent Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Questions & Answers
Well, I don't know just yet.
Is the smoke blue and does it do it the whole time that it is running? If so, the gas could be mixed too rich.
Exactly how long does it run? If it is 10-15 minutes then it is probably your gas cap that is the problem. It is clogged with dirt. The gas cap must be able to breathe or the carburetor won't get the proper gas flow.
Jim
Ryobi 15"... | Answered on Jul 05, 2018
Check the outer tube has not moved forward out of its housing at the engine end as this would make the inner too short.
Ryobi 15"... | Answered on Mar 04, 2018
If it was just bought new I would take it back and let them deal with it.
Ryobi 15"... | Answered on Jan 19, 2018
SORRY this is not the RYOBI website we at fixya do not have parts for any product . try a local dealer of that brand , perhaps they can point you in the right direction
Ryobi 15"... | Answered on Jul 29, 2017
Check on the web. The Ryobi battery is made by Hawker Energy. They call it the Cyclon sealed lead-acid battery. The part number for the Ryobi specific one (OEM) is 0859-1008, but the generic number for the same thing seems to be 0859-1008. I found it on several web sites for $55-$65 + shipping. I have not bought it yet, but the best price that I found was here: http://www.bestlaptopbattery.com/viewbattery.cfm/Sealed-Lead-Acid/All-vendor/0859-1008.htm
I have no connection with this company and have not yet ordered from them. It's the best price that I found ($62 including shipping), but I'm still not sure if it's worth it.
Ryobi 15"... | Answered on Jun 05, 2017
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Ryobi 15"... | Answered on Dec 24, 2016
This was answered in a previous solution
Ryobi 15"... | Answered on Mar 03, 2016
does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
Ryobi 15"... | Answered on Jun 13, 2015
Take a large adjustable wrench and grip the bump head (black plastic) at the same time use your other hand to hold the line spool (orange plastic) rotate the the wrench in a counter clockwise direction slowly and carefully to ensure you are not applying force in any other plane than parallel to the spool or you may damage the bump head threads just until it breaks free. Remove the rest of the way by hand. This happens to me from time to time. If you care you can put a small amount of graphite on the bumphead threads to allow it to come off with hand pressure.
Ryobi 15"... | Answered on Dec 12, 2014
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Ryobi 15"... | Answered on Nov 07, 2014
Maybe try using a pair of channel-lock pliars or a pair of vise grip pliars on the thing. Please vote on this solution.
Ryobi 15"... | Answered on May 17, 2014
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
347 questions posted
Top Ryobi Garden Experts
Nick Olsen
lnbn1975
Dennis Tokarzewski
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
View Most Popular
Ryobi Garden
  • Ryobi Garden
Most Popular Question
ryobi 137r cannot ge head off replace
  • Garden
