Won't start
SOURCE: The Dell Mini-Tower Studio computer
The power source is failing - it will have to be replaced. You can find a generic 400 watts one in almost every shop that sells pc's. Installing it is easy - the cables plug only the right way.
SOURCE: dear sir! my dell optiplex
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
SOURCE: my dell desktop won't start.
check the power connections, if its okay change the power supply or smps
SOURCE: Dell dimension 4600, won't boot,
hi...you can try to factory reset it if you have an authentic version of windows, by restarting your computer and pressing F8 as it starts, would advise backing up all your files however before doing this
SOURCE: Yellow light blinking on my Dell Inspiron one 19 and won't start up
if you have replaced the MB and power supply, then the from IO panel could be the failed component
