I received a used Keurig coffee maker for my birthday but it doesn't do anything but make a whirring sound when you turn the power on. No lights come on even after several minutes. I assume the "heating" light should come on but it doesn't.
SOURCE: How do you drain a Keurig b40 coffee maker?
Empty the water reservoir and put back on the side of the Kurig. Put your hand in the reservoir and slide the disc that monitors the water level back toward the top and and hold in that position,the machine will think there is water. Then put a cup under the head and select a cup. The water will come out. You must hold the disc up inside the reservoir to continue to get the water out.
SOURCE: Keurig b40 elite turns on, then off after a few
I had this problem and it got worse. I had to return the coffee maker to Keurig. They sent a refurbished one, which also had to be sent back. I am getting irritated with the poor quality.
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: Problem with the Keurig Elite
Keurig is having a big problem with this. When you turn it on, pick up the reservoir and place it back down. What you are hearing is the unit trying to pull the water through and it won't. It will try for a minute and then shut itself off. So power on, lift and lower water unit and it should be good. CALL KEURIG and tell them about the problem. If enough of us call then maybe they will do something.
