My samsung wont turn on but how ever if i put it on charge it will show battery icon for 10 sec then just dead again
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
SOURCE: I can't turn on my phone ><
Try to format your phone, use the following steps.
Switch off the phone. Press phone on again. Now hold down the following three buttons: Green (call answer) button, (* )button, and '3' button. Format is complete when you see 'Choose Country' option. All your data in phone memory will belost, but your data in the memory card will still be there. if this does not work, take your phone to the service center and have it flashed
SOURCE: I have 10 day old Nokia e52, will not charge,
The best thing to do is go back to your dealer.
Check a new battery ,ifnot try a different charger ifnot ask for a different phone!
SOURCE: Samsung Tocco Ultra wont charge or turn on.
you have probly blowed your battery (aka) a battery leak check your battery to see in you can squese it if you can then its leaked and you need to buy a new battery from amazon or somewhere else for about 5 pound plus P&P
