I need to download the drivers for Olympus VN-4100PC Digital Voice Recorder.
Hi
Driver related problems can be easily solved on this page: Driver Update Software for XP Vista 7 8 enjoy
I called the number and here is the link that has the software and drivers.
http://www.olympusamerica.com/files/digitalwaveplayer.zip
This driver will enable the VN-120PC, VN-240PC, VN-480PC, VN-960PC,
VN-2100PC, VN-3100PC and VN-4100PC digital audio recorders to operate
with 64-bit editions of Windows Vista(TM) operating systems. Before
installing the driver, Digital Wave Player 2.1.4 or later must be
installed on the computer. (Compressed .zip file 1.73MB) (09/2009).
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1079&os=w
If you checked their website and did not see the drivers for download then you will need to contact them to have them send the drivers to you. Their telephone number is 888-553-4448 option 5 and then option 2 for voice recorders.
Olympus is ********
The solution their site offers is to purchse the program again. here's the link:
https://emporium.olympus.com/innards/empProdDetails.asp?sku=149320-410
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
I need the driver of Olympus VN-4100PC for Windows XP
cant find the driver
I tried to download the drivers for my girlfriend on her new computer that runs vista. It will not work. The software runs fine on my XP operating system. It is enough to drive you CRAZY!
Same here but i have a VN-3100pc...hey, Lanceman65 where did you find those drivers?
where can i download the drivers for the olympus vn 4100pc for vista thanks...
I need the drivers for Olympus vn-4100pc digital voice recorder
how to load software for recorder
lost serial number needed to load software
