Has become more frequent recently, used to be a rare thing but now its every time i use it.
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
SOURCE: Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
SOURCE: I have a delta 36-600
In my Delta table saw the motor and blade turns but it can't cut even MDF, the blade stops as motor runs super strong. It seems to be a clutch problem but I am not sure other parts such as belt, gears or ... involved. I appreciate any help.
