Hello, I have set up my voice messages but when an someone calls my extension, the operator message comes on asking if the caller would like to be directed to a different extension or to speak with our operator. The caller doesn't hear my voice message and simply gets the message instead. How can I set it up so it gets activated and so that callers can leave me messages? Thanks! Also - my voicemail lady speaks french. I'd like to switch her to english. How?
SOURCE: As the receptionist I take calls and then transfer
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
SOURCE: All the calls we recieve in the office go through
Haven't you solved this yet? When we install a system, we reserve THREE buttons for voice mail functions. One is VM Transfer, one is 2 Way Transfer, and one is VM Record. In order you pick 3 buttons press PROGRAM one of the buttons and dial in order 94 500 STORE 01 500 STORE and 90 500 STORE, assuming your voice mail is on the default extension of 500. To send a call to someone's voice mail you press VMT and his DSS button or dial his extension and hang up. The outside party will get all of his greeting. If you want to prompt the user, like you would if you were taking a pink slip, you press 2W Transfer and his extension and carry on a conversation with the outside party. The message records in their mailbox as a new message. If you want to silently record into your OWN box, you press the VM Record button and your conversation is recorded into your own box as a new or old message, depending on how the system is set up.
There are other variations, including a single button transfer into someone's mailbox and some other features that are covered in you telephone sytsem OM or User's manual under Customizing your phone.
Carl
