SOURCE: CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
SOURCE: loading paper tape
when you first get the calculator there is a black piece of plastic in the very back of the calculator printer with a sliver piece of metal under neath it. push the paper in between the black piece of plastic and the piece of metal and keep pushing feed. at first when i tried this it wouldn't work, but you have to push the paper hard without ruining the piece of paper
hopefully you understand this
and if you have any more questions just please ask
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
SOURCE: standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
