20 Most Recent
Casio HR 100TM Portable Printing Calculator Questions & Answers
How do I get a casio hr100tm to print the total?
Once you enter your number like so (5.00 press (+) 11.00 (+) 5.00 (-) then press the *key, should be bottom key next to + = key). Hope this helps, sorry to be so late with an answer.............
Casio HR-100TM. is there a demo step by step on replacing ink.
The ink supply is a small roller. Remove the clear plastic cover over the (printed) paper and the roller will lift out. It only takes a couple minutes to do the job. I suggest not wearing anything white as you will probably get a little ink on your fingers.
It won't feed. How do I install the paper?
Try clean the tiny black roller in the back of the black plastic (see picture). It doesn't pick up the paper when it's too dirty and dusty. I wetted a tiny piece of paper towel with alcohol, pressed it on the roller and pressed the "feed" button so that the roller spins and gets clean up. Hope it helps.
Casio hr 100tm manual
Try to use the AC adapter and plug it to your household current and the calculator and the "E" should go away! Not sure if it's the batteries or just what? It happened to me and that's how I solved that problem! Good luck, let me know!
How do I programed sales taxes on my adding machine?
Sorry it took so long. I had to research and this what I found posted:
Traci Lopez
Press the CA button twice. Then push and hold down the %/set key until the 0 disappears and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate. Posted on Feb 25, 2008
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
