Sony Ericsson Hazel J20i GreenHeart Superior Cell Phone Logo
Posted on Aug 22, 2012
My J20i handset not support for voice calls but support for media files
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
83
Points
  • Anonymous Jul 15, 2013
    I have the same problem
When programing our incoming phone message this is a lot of static on the message which makes the message hard to hear. How do we correct this issue?
Cordless land line phone:
  • If it is possible to set the greeting from the base speaker phone, use that.
  • If the base does not have a VOX speaker, move the handset and the base away from anything that emits elelctro magnetic RF...like wifi access points, microwaves, etc and set the greeting.
Cell Phone:
  • Avoid using the handset to set the voice greeting unless your handset supports a visual voicemail service that captures the audio greeting first and then sends the audio file over the IP.
  • Call your cellphone# from a landline, hit # or * and your PIN, and access the greeting menu from there.
  • If your cellphone and carrier support Wifi calls, VoLTE or Packet switched voice service, set your handset up for hat feature. On an iPhone it looks like this:
2answers
No incoming voice heard during telephone conversation!
I am checking possible solutions for you, meanwhile can you please test in speakerphone mode. So we can conclude whether its Function or Hardware related issue.
Thank you in advance
Want to get my photos from phone memory to the computer
Just connect USB attached to your phone and computer then simply copy your files to your computer.
13helpful
8helpful
2answers
How do access my panasonic kx-tga101s voicmail ?
First of all; Do you have the user guide manual? If not you can download it for free at...www.static.tigerdirect.com/pdf/panasonic_kxtg10325_manual.pdf
This manual addresses handset kx-tga 101s.
The unit lets you know when you have new voice mail, in the following ways; "new voice mail" is displayed on the handset; The message indicator, on the handset, flashes slowly if message alert is on. In order to listen to your voice mail messages, you must dial the telephone service providers voice mail access number. If the handset still indicates messages that have been listened to turn it off by pressing and holding "CLEAR" until handset beeps.
Do you subscribe to a service package that includes voice mail? If so, to use that service turn off the answering machine; And use the instructions provided by your service provider. If you want to use the answering system, call your service provider to deactivate your voice mail service. If service provider cannot do this then set the answering system "RING COUNT" so the system answers calls before voice mail. Check with your service provider to find out what the ring count of the voice mail service is , then make the answering system ring count so it answers first.
Let me know if this answered your question.
FixYa [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2answers
My clutch wont play media files i send it to thru bluetooth why?
The file your trying to transfer is not supported by the clutch. Here are the files that are only supported by it.
AVI
15fps 128 x 96
H.263
15fps 128 x 96
MPEG
15fps 128 x 96
Voice dialing on the i870 motorola phone
Using a Voice Name
Follow the prompts of your voice dialing service, first which means that you need to run the set up of this feature. Each number can be assigned a voice dialing option, which the phone must be trained to recognize.
If you have created a voice name in Contacts for the number you want to call, say the voice name into your handset to enter the number.You can use a voice name to enter a handset number
with the flip open or closed.
1. Press and hold t until a prompt appears telling
you to say the voice name.
2. Speaking into the microphone, say the voice name assigned to the number you want to call.
Your handset plays the name back to you.
If you are making a Private call, press and hold the
PTT button to place the call.
If you are making a phone call, the call is placed
automatically.
(Tip: To stop a phone call from being completed,
press . if the flip is closed or press e.)
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
