20 Most Recent
Sony Ericsson Hazel J20i GreenHeart Superior Cell Phone Questions & Answers
Sony ericsson j20i speaker problem
When the speaker does not work, there can be different causes. Something got in the headphone plug, preventing the connection to the speaker when the headphone plug is out. Another bad connection in the phone, or even a defect loudspeaker. When you are no tech, just bring the phone to a repair shop and let a tech review the problem.
I would blow in the headphone connector with a bellow a photographer uses to blow away dust from the lens and sensor. DONT blow in yourself, because of the moist you bring in. And I would plug and unplug a few times to see if that can solve the problem. Not to often and if it does not help? please do option 1 visit a tech.
Download whatsapp
Search your "app store" type software on your phone, or alternatively go to whatsapp on your browser and download from there
Toshiba camileo s10 wont charge
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
