I have a Maytag MDG7600AWW LP gas dryer which was recently converted from natural gas The problem is that the gas burner/ valve will ignite properly but after a few seconds of operating normally it will begin to pop-back and then the flame will burn constantly down the manifold tube near the valve assembly or just off of the gas outlet of the valve body which causes it to run hot at the valve body shutting the burner off. All changes were made to the valve assembly including resetting the air adjustment at the burner manifold Could this be a gas pressure problem?
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
SOURCE: How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
SOURCE: Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
I wote a short essay on this problem. To keep from being redundant I have it HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
