20 Most Recent Maytag Neptune MCG8000AW Gas Dryer Questions & Answers
Maytag mcg8000aww gas drying center (has upper and
Check your to make sure a heat setting is positively made. https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help Replace solenoids on gas valve I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
10/25/2017 12:54:28 PM • Maytag Neptune... • Answered on Oct 25, 2017
How to replace belt
try going to repairclinic.com and they will have digrams of how to
8/26/2015 7:35:30 PM • Maytag Neptune... • Answered on Aug 26, 2015
I have a maytage neptune mcg8000aww, the machine is plugged in but there seems to be no power to it.
bad thermal shut off fuse , this burns out usually due to overheating, so just replacing it wont suffice? check ur venting and cycling thermostat also.
12/9/2014 7:03:17 PM • Maytag Neptune... • Answered on Dec 09, 2014
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
8/31/2014 10:42:29 PM • Maytag Neptune... • Answered on Aug 31, 2014
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
8/31/2014 9:17:14 PM • Maytag Neptune... • Answered on Aug 31, 2014
Drum of Maytag dryer Model # MCG8000AWW is becoming black and dirty
I would start by taking the dryer back off and cleaning all the lint out. on mine there was lint by the burner and burning and blowing into dryer
4/7/2014 6:00:53 AM • Maytag Neptune... • Answered on Apr 07, 2014
Trying to take cabinet off my MAYTAG MCG8000AWW
And you can't find that first screw that undoes the whole thing? I am not familiar with this unit, but have found that most dryers magically open the same way. If you open the dryer door and look around where the dryer door seats, you "may" find 2 screws that hold the top down. Take those screws out and the top will lift up and then you need to look inside the front panel to find a couple of other screws which hold the whole can of worms together. Be aware, once you loosen the front panel, the drum rides on that panel so you need to support the drum when you remove that panel. Hope this helps
10/19/2013 2:08:27 AM • Maytag Neptune... • Answered on Oct 19, 2013
Maytag neptune gas dryer Model # P MD64000AWW
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
10/7/2013 9:18:31 PM • Maytag Neptune... • Answered on Oct 07, 2013
Dryer no heat
First check your igniter, just because it glows does not mean that it's good it has to reach a pre-set temperature to open the gas valve. If that checks out test your thermal fuse. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
8/5/2013 3:25:31 AM • Maytag Neptune... • Answered on Aug 05, 2013
Gas dryer won't heat
check to see if it heats up for the first 2 minutes if it does then i would replace the coils on the valve if not check the thermal fuse on the blower housing
2/25/2013 2:32:23 AM • Maytag Neptune... • Answered on Feb 25, 2013
Lint in lower dryer mcg8000aw
Here is the complete service manual for that unit. Be sure to keep a copy! You may need it in the future. It is worth it's weight in gold!Happy Thanksgiving!
11/22/2012 1:22:38 AM • Maytag Neptune... • Answered on Nov 22, 2012
Where is the ignitor located in the maytag mcg8000aww
inside the burner funnel tube at the bottom of the dryer below the drum,you need to remove the front panel to access the ignitor
8/27/2012 4:51:57 PM • Maytag Neptune... • Answered on Aug 27, 2012
Maytag Neptune MCG8000AW Gas Dryer Logo
91 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
ignitor located in maytag mcg8000aww
  • Dryers
