Phone working properly, but phone book not opening, theams not opening. phone book showing contact memory exactly but not showing any numbers and name
SOURCE: while installing theams, it shows "file corrupted"
some .sis files are not compatible with nokia n70 there are different versions of symbian OS. maybe the themes you download is not compatible/
SOURCE: camera on stand by mode.failed operation of move file
I had same problem with same model – the applied solution is below
Just format the storage card & it should work!
Kiran Pawar
SOURCE: name won't show when some one calls me only the number E63 Nokia
You have duplicate contacts. Remove the duplicates and it will be fine
SOURCE: Nokia N95 8GB. Contact names not showing
There are 2 reasons why a Nokia cell does this.
1. If the same no. is entered in the handset twice or more than once whether it is under the same name or different names does not matter.
2. The other reason is that it will show a name if it is using "First Name". "Last Name", "Company" fields. Please check both.
Fix:
You should use the fields mentioned to list down names, this way the no. will show up when you call them or they calls you. Also remove duplicates!
SOURCE: my Nokia e63 does not show names of my contacts when
Probably you have multiple names on the same number in your contacts due to storing contact number more than once, truncation, etc. Use Search Tool facility in Office, search contacts using the number you have problem with. If it found multiple names, choose one you like and delete all the others.
