My daughter has a Sansa Shaker that needs repair. When playing music, sound can be heard if headphones or external speakers are connected to either headphone jack, but if these are not connected, no sound comes out of the built-in speaker. Having some experience with electronics in the family, we would like to try to repair it, but are having trouble opening the case. We have gotten the base off, and removed the visible screws but cannot open the case any further to access the internal speaker. Does anyone have any ideas how we could open the case, or where there might be a service manual for the Shaker? Many thanks!
SOURCE: How to open up a Sansa C140?
I too had a problem with the headphone jack. It took me a while, and a few scratches on my Sansa C140 case, but I FINALLY figured out how to seperate the case.
1) POP the black top (with the buttons and display cover) off. Get under the edge and pry, working your way around. It's just snapped on.
2) With that cover off, you will see four (4) screws, one on each corner. Remove these. The BOTTOM will now come off (may require a little wiggling to slip the battery terminals out of their grooves).
3) You should now be left with the main board contained within the middle of the plastic case. Removing the board is a CHALLENGE as it is held (not tightly) by a couple of tabs, as well as the headphone jack and the connection port.
Be careful when working to get the board free. I ended up popping two of the solder-tabs off the board for the headphone jack when "prying" the board out of the case. Luckily I was able to fix it when re-soldering the jack to the board. And one of these may have already bad (requiring the repair in the first place).
Reverse the steps to put it back together, again being careful when re-inserting the board back into the casing.
Good luck. Hope this answer still find you in time...
SOURCE: headphone jack
The Sansas Earphone Jack soldier is very cheap try bending it or placing something extra to hold the jacks connection to the player. when closed its not niticeable, no need for soldiering. Try it. Contact me if you want a video of what i did. hope this works.
