Boating Logo
james king Posted on Aug 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
2005 evinrude outboard
qumozheklj
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on May 29, 2014
qumozheklj
Contributor
Level 1:
New Friend:
Answers
28
Questions
19
Helped
31972
Points
42
1973 1991 johnson evinrude outboard 60hp 235hp 3 cylinder v4 v6 2 stroke workshop service repair manual pdf download/
http://www.repair-guidebook.com/1973-1991-johnson-evinrude-outboard-60hp-235hp-3-cylinder-v4-v6-2-stroke-workshop-service-repair-manual-pdf-download/
Anonymous
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Aug 19, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
106
Questions
Helped
35464
Points
297
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
steve richardson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2014
steve richardson
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
881
Points
I know i need a knew cable i put in trouble shooting for all how do i install it the cable is broke i know that. because it broke down below on the motor i dont know where it hooks up on the top of the motor 1990 40 hp evinrude model number is te-40-elesr cable tilt assist.what dont you guys understand. where can i get a diagram where the cable hooks up on the motor. duh
5 Related Answers
Thomas F. Schneider
  • 2715 Answers
  • Posted on Dec 23, 2008
SOURCE: gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Anonymous
  • 52 Answers
  • Posted on Apr 14, 2009
SOURCE: 1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Anonymous
  • 65 Answers
  • Posted on May 08, 2009
SOURCE: evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
Anonymous
  • 23 Answers
  • Posted on Jun 19, 2009
SOURCE: Can not lower the motor manually
There is a screw usally on the right side looking at back of motor use large screw driver loosen motor will come down I guess you have trim and tilt
Editor925
Dean
  • 285 Answers
  • Posted on Jun 20, 2009
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
1helpful
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 • Boating
2answers
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
1helpful
Where does the water exit a 1971 25 hp evinrude? how do I know it's pumping water?
I do believe the water jets are down on the lower unit by the prop. There should be a white swirl of white bubbles shooting out.
4helpful
Jun 15, 2009 • Boating
1helpful
Mar 28, 2009 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
