Brother FAX-2920 Plain Paper Laser Logo
Anonymous Posted on Dec 19, 2008
Paper Jam The paper trail won't sometimes take and lift the paper. And when it does the paper moves 1-3inches to the toner section, there it get stuck and it makes some funny noises. Then it says please remove the paper, have removed the paper tried to fix the problem. But I may have discoverd the problem why it won't take the paper sometimes, on the left side on the paper trail it points abit out, have cleaned most of the intake wheels. Need answer fast need to be up and running as fast as possible.^^
Anonymous
Level 2:
  • Expert 318 Answers
  • Posted on Dec 19, 2008
Anonymous
Expert
Level 2:
Answers
318
Questions
Helped
150416
Points
879
I think you have a problem with the arm that is attached from the drum to the drive gear of the drum.It happen sometimes that that arm or the mechanism that retreat and locked to the drum when you open and close the door is faulty.The arm hep to unlock the drum when you open the door to remove the drum unit.Now if you insert the drum unit that machanism do not lock the drum in possition that cause the drum not to rotate and cause the PAPER JAMS.
You have to open the left panel of the fax and inspect the mechanism.
  • Anonymous Dec 19, 2008
Samsung 4300 Printer. Why my printer shows Jam 1 or Install Toner yet there is no jammed paper.
Question edited for clarity, spelling of maker and typos.
Question moved to correct category.
If it says there is a paper jam, there is usually a small piece of torn paper over a sensor. Remove toner cartridge, open all access doors and check with a flashlight.
For the toner message, tap the cartridge to settle any toner that is stuck.
Machine is reading paper jam but the paper was removed and the reading still persist
which Printer are you using? You might need to open the printer paper feeder or where the toner is loaded or a paper jam door in your printer to clear the paper jam. sometimes its a torn piece of paper that's stuck in the paper print rail that might trigger the paper jam signal.
How Do I Open Samsung Xpress M2070w printer machine to Remove Paperjam
1, Paper jams occur when papers are stuck inside the laser printer. It affects the entire printing process. Lift the scanner unit and open the jam cover. Raise the fuser dummy cover. Discard the jammed paper by pulling it outwards gently. Close the fuser dummy cover and the jam cover.
2, Lower the scanner unit. Open the middle cover and take the toner cartridge from its slot. Remove the jammed papers and reinstall the toner cartridge. Close the middle cover and the scanner unit.
3, If the paper jam error still occurs, look for paper jams in the input tray area and remove them.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
1helpful
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Hp p1606dn printer paper jam under the toner
Have you tried to lift the green handle from right of the metal plate that sits under cartridge? If you cand see the piece of paper, maybe you can grab it with a tweezers. Otherways you will need to remove the front dor assembly and then the feed/transport section. With some technical skills, you will succed to put it back, but don't start if is the first time you disassemble an printer.
HOW DO I CLEAR THE PAPER JAM 1? I opened all the doors and checked to see if any paper is stuck somewhere. There is nothing to keep it from starting again.
Did you check the fusing section from back door? When you open the rear door you can access the fusing unit (hotest place!!!). Sometimes the paper stacks below the stripping pawls of hot roller and you can't see it easy. Look harder! Pull out the whole paper tray and check below (printer bottom) for paper sheet. Lift upper cover and remove cartridge. You will see little green lever. Lift it up! Look for piece of paper around the little black pawl (paper sensor after registration roller). Restart printer!
Good luck
pifonski
2answers
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
5helpful
3answers
HP 2840 Jam in Print Paper Path
There are 2 primary paper sensors. One is the registration sensor where the paper feeds in, the second is associated with the fuser unit.
The first sensor is located under a cover under the transfer unit.
i) Open the door
ii) Lift out the transfer unit (Q3964A)
iii) Locate the black plastic cover plate with a small green flap in the centre. This assembly is directly under where the transfer unit was installed.
iv) There are 2 shiny screws that secure this cover plate. Carefully remove these screws.
v) Lift out the black cover plate by lifting the left section up first which allows the right section to come clear of gears.
vi) Check for paper obstructing the small movable lever under the cover plate.
vii) To reinstall the cover plate, insert the right hand side down first and line up with the mounting holes.
I can supply photos if required.
3helpful
2answers
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Hl 2040 laser printer
Check for a piece of paper caught in the fuser section. Sometimes a small piece will wedge itself in. Vacuum out any residual toner that may be in the paper path.
Norman Weimar
Norman Weimar
k24674
