20 Most Recent
Samsung ML-2150 Laser Printer Questions & Answers
Toner low
If you have toner chip , please change toner chip, than you can see new life toner cartridge
My samsung 2150 duplex jam
The printer is telling you it is the wrong toner not an old toner this is either because it is the wrong toner or a fault with the printer has caused it to think its the wrong toner, try taking out the toner and putting it back in again, then try replace the toner with a new one. if this doesn't work the printer is probably got a broken component.
HOW DO I CLEAR THE PAPER JAM 1?
I opened all the
Did you check the fusing section from back door? When you open the rear door you can access the fusing unit (hotest place!!!). Sometimes the paper stacks below the stripping pawls of hot roller and you can't see it easy. Look harder! Pull out the whole paper tray and check below (printer bottom) for paper sheet. Lift upper cover and remove cartridge. You will see little green lever. Lift it up! Look for piece of paper around the little black pawl (paper sensor after registration roller). Restart printer!
Good luck
pifonski
Appear duplex jam at display
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
The ml-2150 has a serial inferface option. In what
you are talking about the serial parallel cable, almost all the store that is selling computer, parts and accessories are selling these parallel cable for printers printer such as epson lx-300+ uses these kind of cable check your local store for stocks
I have lost my CD
This is a link to the downloads page for your printer.
http://www.samsung.com/us/support/downloads/ML-2150
You may need the universal drivers and the management suite is under the software section.
Basically all you get on the cd is the driver, the manual and the management suite which are there.
