After putting soap in the dispenser, I close it but it always pops open immediately. It is not catching
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
SOURCE: asko d1876 (black)- despenser problems
it sound like you need a new pcb,if the dispenser is making a buzzing sound,then thats it remove the control panel and see if the tracking is burnt anywhere,also replace the wax motor on the drying vent.
SOURCE: soap dispenser broken, can i replace it?
you can do it your self. No problemo. Two electric connectors, six screws 20 TORX.
SOURCE: The soap isn't emptying out of the compartment
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Hi
Dishwashers use Bi-Metal strip to
allow the dispenser to open/close. This strip when heat up causes the soap door
spring to open up the dispenser. If this strip is not heated doesn't allow the
door to open. The strip may not be getting 120V or maybe disconnected. Newer
(plastic liner) dishwashers use a wax motor to open the soap dispenser. The
plunger inside the wax motor slowly moves and pushes the plunger and door
open. And, if this wax motor doesn't receive 120 volts, then it'll not work.
Please check the voltage to the wax motor/Bi-metal strip; also inspect the
connections to these.
Hope this helps...
Daniel
